| I need to pick your brains for a bit. I have searched to no avail. I have gas in the plenum, little puddles. The whole plenum was taken off and cleaned out 2 months ago, PCV and EGR deletes have been performed. The FPR and Fuel damper don't look to be the culprits as the vacuum lines are dry. Plugs look normal, changing them out anyway. Any ideas? I don't want to put it back together like this and its my DD. Car has a stumble and a hesitation at mid range. Always has, suppose this could be the issue though.
